Question on Grounds for the car???
Old Sep 18, 2006 | 10:51 AM
asudecat's Avatar
Does anyone know how many grounds are on the car, inside and out???
And where they might be?
I think were missing a ground somewhere.
We found 3 under the dash and I think 6 in the engine bay not including the battery grounds.
Maybe someone can direct me to a diagram or something.
thanks
Old Sep 18, 2006 | 03:43 PM
asudecat's Avatar
Re: Question on Grounds for the car???
bump for someone that might know
Old Sep 18, 2006 | 04:03 PM
Guest47904's Avatar
Guest
I assume it's for the 96 Pontiac on cardomain.
Here goes
7 in the engine bay.
RH shock tower
LH side of radiator support
RH side of radiator support
right side of engine near the AC compressor
Left frame rail to engine
Left front cylinder head
Right side of block above the starter.
7 inside the body
base of LH A pillar
Base of RH A pillar
Floor pan under console
Floor pan LH rocker panel
roof left of dome light
Rh wheel well
hatch release bracket
Old Sep 18, 2006 | 04:28 PM
TobyZ28's Avatar
Whats/where is the frame rail exactly? I don't think mine has that ground (looks like it was moved to the same place as my ICM...)
Old Sep 18, 2006 | 04:47 PM
There is a braided groung strap from the coil mounting stud to the frame rail.
Old Sep 18, 2006 | 04:59 PM
TobyZ28's Avatar
Oops, k got it for some reason i was thinking he was referring to a rail on the block.
Old Sep 18, 2006 | 05:54 PM
asudecat's Avatar
Ok what we have came down to is the BODY CONTROL MODULE.
For some reason it's not grounded and is connected to the interior lights, theft deterent, stereo, trunk release, accesories, ect......
anyone have any idea what im talking about or can translate it any better????
ChrisFrez
Dec 21, 2014 09:47 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Injuneer
Dec 15, 2014 09:36 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
