Having problems getting DS off :(
Old Jan 13, 2004 | 05:47 PM
raxxus's Avatar
I found a place nearby that can balance my driveshaft for 30.00, so I'm going to go for that. I just need help getting it off. I have done this before, but for some reason after the four bolts aer out, and the 2 clips, it doesnt want to budge. What should I do?
Old Jan 13, 2004 | 06:03 PM
Use something as lever to push it forward to get the bearing caps loose from the pinion yoke. You will then be able to drop the rear of it down and pull it out.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
