Having major problems with voltage and A/C.
Old Jun 4, 2004 | 07:14 PM
Kreinmc's Avatar
Ok I have some major problems. The other day the A/C stopped working as did the power steering. When I looked under the hood I had a broken belt. After I replaced the belt I was only getting about 10-11 volts on my gauge and when i turned the A/C on I would get a check gauges light and the voltage would go way down. I had the alternator checked and I was told the alternator was bad so I replaced it and that did not solve the problem. Now looking under the hood I can see that when I turn the A/C on that the A/C pulley completely stops turning. So, is my A/C clutch messed up or is it the entire compressor? How do I figure this out?
Old Jun 4, 2004 | 07:39 PM
Josh'95Z28conv's Avatar
Sounds like your compressor locked up. That could cause it to throw a belt too...
silvermansteve
Mar 4, 2015 05:02 PM
karnykamaro
Feb 2, 2015 01:37 PM
Jazsun
Dec 29, 2014 12:14 PM
slothgrant
Aug 22, 2002 03:01 PM
