having 95 z28 six speed built costs
I contacted a local shop for recommendations. Just wanted to know what you guys think as far as what I should pay. I am not very knowledgeable when it comes to this stuff so any advice would be appreciated. The engine was rebuilt 30,000 miles ago. It is all 100% stock. I want to get to 400+ hp at wheels. My budget isn't an issue. I can go to 12-13k. I was looking at loyd elliott le3 package. What should I pay for complete build, clutch, flywheel, rear end and tune? Or what should I pay for each.
Re: having 95 z28 six speed built costs
This is a hard question to answer. I was lucky to find a guy that was selling a complete drivetrain, bell housing, transmission (6 speed T56) used clutch, hydraulic clutch parts, drive shaft and a badly rusted complete rear end for less than $1000. The rear end had disc brakes and I'll be using the parts to convert my drum brakes. The engine I'm using came from a 95 Chevy Caprice. Rebuilding it, bore and stroke and full blueprinting, is in progress. Cost, $30 a cylinder and a rotating assembly which cost around $900. You need to find a good machine shop. That's the key. You can get great info from you tube. One last thing, with the amount of money you will be spending, you could have bought a newer and faster car, but we like the shape and look of the 3rd gen Camaro, and it is my son's first car. It took me about a year to locate and buy the parts needed to do this swap, and I'm still not through. If you put a timing requirement on this project, it won't be fun; so many things to work out.
The ultimate clutch is the McLeod Street Twin, which comes with steel or aluminum flywheel ($1,300 -$1,600). With a strong clutch, 400+HP to the rear wheels, and sticky tires, the stock 10-bolt is not likely to survive. You can get bolt-in replacements, GM 12-bolt, Strange (Dana) 60, or Ford 9-inch for $2,500 - $3,000.
Rebuilding the T56 could run about $1,000 - $2,200.
All of this assumes you will do the installs yourself.
Typical source for drivetrain parts:
McLeod Street Twin LT1 Clutch Kit with Steel Flywheel (horsepower capacity: 1200) - Tick Performance
Six Speed Rebuilds - 1993-2002 Camaro & Trans Am - T56 Rebuild Packages - Tick Performance
A mail order tune will run you $250 - $350. A dyno tune will be $500 and up.
Don't forget your suspension, fuel pump, exhaust, sticky tires, etc.
I could send you a mods list for a 381 w/ a 300-shot of nitrous - 800HP/800Lb-Ft at the flywheel. The rotating assembly was chosen based on an ultimate goal of 1,000HP, but that upgrade was never done.
When the engine was first built, it still had a stock T56 with a McLeod Street Twin (steel), Mark Williams chrome moly driveshaft, and Strange 12-bolt with 3.73 gears. When I did the conversion to the TH400, I sold the complete McLeod/T56/hydraulics as a package for a conversion, and the T56 needed a rebuild. Stock T56 was not happy behind that kind of torque, or 5,000RPM clutch dumps.
The engine/trans was handled by a shop.... everything else I did myself.
Tick Performance did mine(T56) for $1400. Replaced all bearings, syncros(carbon if I recall), fork pads, and upgraded to the steel fork for 2/3 shift. Just a minor upgrade to the stock unit.
I had no gears bad in my T56.
My problem with it was intermittent grinding in 1-4 gears. Turns out the bearings were worn allowing the preload to get out of spec.
Jonathan knows his stuff and answered every question I asked....a top notch pro on these T56's. I've been very happy with the rebuild. I'm close to the their shop and they were very helpful.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Dec 17, 2014 02:50 PM
