Has anyone done the SLP fan switch install?
Old Feb 12, 2004 | 09:05 PM
  #16
naztyz28's Avatar
i havent found anyone cheaper then 60 its worth it if you ask me. i put the switch were the cig lighter used to be
Old Feb 12, 2004 | 09:08 PM
  #17
Cerwin Vega Fan's Avatar
Where did you find it for $60, cheapest place I have found it for is $70.
Old Feb 12, 2004 | 09:13 PM
  #18
naztyz28's Avatar
its called stealth motorsports dont know if there still around tho
it was about a year ago
Old Feb 12, 2004 | 09:14 PM
  #19
Cahill93Z's Avatar
I say do it your self. i did it, all i had to do was buy a switch. I already had copper wire. Costed about $3, and it works great. If this 16 yo kid could do it im sure you can.
Old Feb 22, 2004 | 05:49 PM
  #20
notstock4long's Avatar
Originally posted by FastWhiteTA
You must have gotten bad info somewhere, cause when the SLP switch is in the "off" position, it doesn't interfere w/ the automatic fan operation controlled by the PCM. Now, when it's on I'm sure it probably stays where you put it.
Actually, you are wrong about that. Even if you have your switch on low speed op, and the computer tells the high speed to kick on, it still will. Check out this kit too.
Richardan15
May 30, 2015 08:36 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
slothgrant
Aug 22, 2002 03:01 PM
