Hardened Pushrods
Old Feb 13, 2007 | 07:54 PM
  #76
DelSoto's Avatar
Originally Posted by SS RRR
Looks around some more
Can't seem to locate a whole lot of that around here! I see ALOT of dyno numbers floating around, but no ET's.
370rwhp/355rwtq
My argument is just as valid by stating there are hardened pushrods out there that WORK for a mild setup as yours is claiming they don't. As a matter of fact those who say they don't work are in a minority compared to those setups that have used them successfully. Think about that one. We've already been through this. Sorry you were late to the party.
I can see both sides of the argument but in the manner in which you thrash Bret's input obviously shows that you have something against him. To quote a comedian that argued the same type of point. I can drive with my feet...that don't necessarily make it a good idea. I'm glad everything worked out for you and your part decision. Next time just say what worked for you without trying to shove it down our throats and leave it be. I come on here looking for answers and get ideas as well as advice and personally, I would take Bret's over yours. I don't know Bret and I am not saying you give bad advice ...I think it has to do more with your delivery. I think Bret defends himself well and knows when to walk away from an argument (whereas others do not). Actually I think he is too nice at times.
Old Feb 13, 2007 | 09:06 PM
  #77
SS RRR's Avatar
Originally Posted by 89385formula
I suppose what i was saying is that my argument is 2x as good as yours because i showed that cheap hardened pushrods fail quite often, since it happened twice to me personally. Whereas you had 1 engine combo that worked with them....not 2, so i guess its that simple.
For you, maybe. Did you use guideplates?
I think your arguing for the sake of argument, regardless of whether or not your mild combo worked well for you, and your cheap hardened pushrods did or didn't fail, would you not agree for someone building another engine or valvetrain, that it would be worth the additional money for piece of mind knowing that you have a better part that is less prone to failure for a marginal cost? $50 extra for better pushrods>$xxx+ for engine damage.
Untrue. A whole lot of things can happen other than problematic pushrods. You must take the entire valvetrain into account. It's just like the Comp R debacle. Bret himself admitted in this thread that the plunger retainers couldn't handle the abuse of pushrod flex or valve float.. etc... Now is that the lifter's fault? I think not. Even in the original "Comp R" thread he states he can only "guess" why they fail and to only assume he's right.
And there are multiple people using them with great success. Me being one of them. But as Bret so elequently put it.. I'm lucky and ignorant.
That's fantastic. However I will defend the fact that not all hardened pushrods are junk due to my own testimonial. If you choose not to listen that is absolutely fine with me. I'm not trying to convert the masses. I'm merely telling anyone who bothers to read that I have supplied a link for hardened pushrods that WORK in mild applications. The one thing that has slipped my mind is the fact when using a mild application like a hotcam or my setup IMO guideplates should be used.
I am fully aware Bret has rock star status on this board. I always choose to read/comprehend/listen to more opinions than one. Perhaps that's the reason why I'm soooo lucky!
Old Feb 13, 2007 | 09:07 PM
  #78
SStrokerAce's Avatar
Man your such a dummy..... when I said that the Comp R's couldn't take the standard loads that a valvetrain will see OVER 6200rpm that PROVED my point, not yours. It's funny that a STOCK OEM lifter CAN handle the SAME VALVETRAIN and the Comp R's that failed couldn't.
EVERY valvetrain has pushrod flex, valve bounce etc... it all depends how you handle it. Jesus this is like arguing with a 2 year old. How bout we just say "BECAUSE DADDY SAID SO!"
Bret
  #79
buzz12586's Avatar
So SS RRR, if I go with the hardened pushrods you suggested and one of them bends and f*cks over my motor, will you pay to replace it???
Old Feb 13, 2007 | 09:15 PM
  #80
89385formula's Avatar
On the LT1, no guideplates were used.(CC503, SA Comp Pro-mags), on the 5.0 there were guideplates(custom cam, NSA Crane RR's).
Apparently you have a problem with Bret's wording or use of the word "junk". I believe that after seeing enough failures of certain parts he tends to use the term junk more freely for those items. Perhaps the word inferior should be used rather then junk.
I do also find you to be extremely lucky, because i had Comp R's fail as well. Honestly i understand where he is coming from because these things we are seeing are not isolated incidents, and it is better for people to know whats happening out there to these items. Also i treat my advice as i am giving to a complete Newbie, because at one point i was a Newbie and given advice on parts selection...some selections i was assured would work, failed and at the cost of damaging other items, later to find out there was a better option for very little extra money. This is one of those cases where its a very reasonable upgrade, for a small fee for one of the most crucial items in your valvetrain.
Old Feb 13, 2007 | 09:20 PM
  #81
mdacton's Avatar
I like reading all of this....just so you know
Old Feb 13, 2007 | 09:21 PM
  #82
Glad we can entertain you Mike lol!
Old Feb 13, 2007 | 09:23 PM
  #83
mdacton's Avatar
I'm going to forward this to dr.phil.com
and then sell the dvd's
Old Feb 13, 2007 | 09:26 PM
  #84
kline454's Avatar
i dont think this thread will ever end. lol
Old Feb 13, 2007 | 09:27 PM
  #85
mdacton's Avatar
naw it will be locked by the morning probly, sad tho I like reading it
Old Feb 13, 2007 | 09:32 PM
  #86
kline454's Avatar
well sence this is all about pushrods, if i get a shorter pushrod will it move the tip of the rocker back toward the intake or out? right now the tip of my rocker is seting forward toward the out side of the head?
Old Feb 13, 2007 | 09:34 PM
  #87
Yep, shorter moves the tip back towards the intake and longer towards the exhaust.
Bret
Old Feb 13, 2007 | 09:36 PM
  #88
kline454's Avatar
ok thank you!! and im taking your advice and going with chromoly.
kyle
Old Feb 13, 2007 | 09:40 PM
  #89
mdacton's Avatar
kyle
O.k MR. big shot...since you have the extra $40......thanks for braggin
BTW get a length checker, I thought I could order the next size up and it didn't work, and I have a set of PR I can't use
Old Feb 13, 2007 | 09:42 PM
  #90
kline454's Avatar
yeah i got one just got done checking it, going with the 7.150
