Hand tuner/base tune
Old Jun 3, 2012 | 09:40 PM
shook1502's Avatar
I have just got done with my motor and put it all together. Well i didn't want to pay 600 for a full tune, so i had someone do a base tune on my car. well when i got the base tune do i couldn't drive it because i still have a few things that needed to be done with the car before i could drive. So he took my PMC and put it in his car and downloaded a tune and put it back in my car. well everything worked put great, but now when i take off my shift points ain't right.. So... My question is can i use my hand tuner to redo my shift points or would it [edit] the tune that's already been downloaded on the PMC.. i didn't know if i could go in and change it.... THANKS
Last edited by Injuneer; Jun 3, 2012 at 11:39 PM. Reason: Do not attempt to override the language filter.
Old Jun 4, 2012 | 01:42 AM
Red_94Formula's Avatar
Re: Hand tuner/base tune
What mods do you have done to your car? Did you get a higher stall convertor? In what way is it shifting incorrectly? A hand tuner is probably too limited for your setup. This info can help figure out what is wrong. Maybe you can have the tuner person retune it.
Old Jun 4, 2012 | 04:26 AM
shook1502's Avatar
I have a 3000 stall, It shift fine when i drive at speeds. once i get on it, then that's when it wants to no shift in gear till i get off the gas and hit it again, but even then it don't seem to want to shift in to gear sometimes. So i didn't know if i could change that with my tuner, and **** my base tune up?.. Here's most my mods,,,,,CC306 Cam, Hooker LT Headers, Cold air intake, 3000 Stall, Pro MAF, 4:10 Gears, LT1 P/P Heads (valve springs, retainers, etc), Eagle Forged Pistons, 1.6 roller rockers, LT1 P/P Intake, Holly 58mm Throttle Body, 30lb SVO Injectors, Adjustable Fuel Pressure Regulator, Sealed Power Hellfire Piston Ring Set R-19100-35 4.030" Bore 1/16"/1/16"/3/16", JEGS Electric Billet Water Pump, NGK spark plugs, MSD Spark plug wires
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Victor Lamb
Aug 26, 2017 02:52 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Dec 1, 2014 08:08 AM
