Had to hammer that stupid crank hub on...
Old Nov 10, 2003 | 04:41 AM
96 WS6's Avatar
Man that thing was a major PITA. I even threw it in the stove for 20 minutes and it was still a bitch to go on. I hammered metal to metal but I did not hammer too hard and I held the hammer close to the head so I didn't have much leverage. I know it's a no no but most likely it's okay. What would I have been hammering against by hammering the hub on the front of the crank? I mean where would the pressure be? You now before that I tried using the hub bolt to pull it on and I first stripped the beginning 2 threads... then later after I thought I had it worked out I stripped about another inch of threads backing the long bolt out to put the stock bolt in. I already stripped the hole twice and had to install a helicoil just so I could get a bolt to thread in (that stupid helicoil kit was 40 bucks and it looked like it cost 5 bucks to make, arghhhh ). I can't believe out of the entire cam install the hardest part was taking out and reinstalling the hub and scraping the old gasket off the timing cover... that's just ridiculous. Ehhh I just had to bitch for a while.
Old Nov 10, 2003 | 07:06 AM
Don 97 SS's Avatar
That hub is a bear to remove and reinstall. I fortunately had some help from a bud who had some specail tools that made the job easier. I smeared the hub snout with anti-seize and found I didn't need to heat it up. We used a hub tool and screwed it in.
I also installed a keyed hub this round. Do you have a key hub?
I helped a bud install a hub after a cam job a few years ago and we heated the hub in the oven and it went on very easy (with insulated gloves!)
Old Nov 10, 2003 | 07:38 AM
Grease's Avatar
Next time, use a threaded rod to put the crank hub on. that way if you destroy any threads, it will be on the threaded rod.
Boss002
Jan 20, 2016 12:17 PM
13qtr
Jul 19, 2015 05:30 PM
94Form
Jul 17, 2015 10:56 PM
Bz8
Jul 13, 2015 04:46 PM
