Guy's Need you're Input
Old Jun 1, 2006 | 12:24 PM
Jlo's Avatar
Jlo
Hi, I'm rebuilding my LT1 engine, so far I have LE3 heads on the way along with a Bret Bauer cam which I now have. One problem is my rotating assembly, I still don't know if I should go 355 with a 6" rod or a 383, both will be forged. I trying to get into the 11's on motor and 10's on juice. It's a 6spd, and I have eveything except the rotating assmbly. Will I have any clearence issues with the 355 as far as changing oil pan and clearence block. I know 383 have tq but I can spray the 355 and make it up. I other words my "Q" is what are the advantages and dissadvantages of both. It's a 95 Z plan on sprayin 200-250hp. What do you guy's think I should build.
Old Jun 1, 2006 | 03:12 PM
Eric@Victory Racing's Avatar
Re: Guy's Need you're Input
I would go with a 383. Here is a short blockthat would handle 250 shot. If you have any questions, don't hesitate to contact us.
VRE 383 Racer Short Block
Compstar 3.750" Stroke 4340 Crankshaft ,Compstar 6.000" H-Beam Rods
Diamond Pistons, Diamond Pro-Select Rings, Clevite Rod Bearings, Clevite Main Bearings, Clevite Cam Bearings,ARP Main Studs, Splayed 4 Bolt Caps.
carguy0119
Apr 11, 2016 11:11 PM
Red97LT1
Aug 21, 2002 10:31 PM
Red97LT1
Aug 7, 2002 05:45 PM
Omega9
Aug 2, 2002 12:33 AM
Absolute Z28
Jul 19, 2002 02:21 PM
