Guage Help
Old Apr 12, 2004 | 10:56 PM
1995ta's Avatar
Guage Help
I hooked up my A/F and tranny temp tonight, but neither of them work. What wire do I splice into on the PCM for the A/F guage?
Old Apr 12, 2004 | 11:10 PM
You need the purple or purple/white signal wire from the O2 sensors (one is left side, other is right), and they are connected to pins C8 and C20.
Old Apr 13, 2004 | 01:17 PM
1995ta's Avatar
Would this wire be located in the wires going to the pcm? I see 2 purple wires (thicker one is the starter I believe) and the other one is what I have it tapped into....
Old Apr 13, 2004 | 03:10 PM
The purple harness wire from the passenger side O2 sensor is connected to pin #C8 (grey connector) on the PCM. Look at Shoebox's pinout diagram to make sure you have the correct wire.
http://shbox.com/1/1995_pcm_conn_c.jpg
I don't see any other purple wire in the "C" connector. The purple/white stripe wire is on pin #C20.
IndyZman
Oct 22, 2015 02:17 PM
dylan1303
Aug 12, 2015 02:00 AM
alphaauto
Jul 26, 2015 04:40 PM
2QUIK6
Jul 2, 2015 07:02 AM
Ucantcme57
3rd Gen / L98 Engine Tech
Jun 15, 2002 01:46 AM
