Need another Guage....?
Old Jun 14, 2002 | 09:37 AM
Ucantcme57's Avatar
Question Need another Guage....?
Also I forgot this one.. I am putting together my car now and I have been looking at what guages I might want to have I have a three Guage A-pillar and a dual guage pillar that will go somewhere next to the drivers console or under the air vents or on top of the radio I don't know yet. But I have all my stock guages working..
Speed
RPM
Oil Pressure
Volts
Coolant Temp
Fuel Level
Now I need five other spaces filled I was thinking;
NOS Pressure
Trans Temp
Fuel Pressure
Boost
and ??????
Need one more anybody have any ideas????
Thanks for all the help..
Kevin
86 Chevrolet Camaro Iroc Z-28 Fully Loaded With T-Tops
Mods;
Spohn SubFrame Connectors, S&W Race Car Chassis 8 point Roll Cage, 1997 SS Aniversary 3.42 POSI Rear End with 12" Rotors and 4 Piston PBR Calipers, Balanced Drive shaft... Others soon to come...
Best times before any mods done, Complety Stock;15.6 @ 87mph
Waiting for the tracks to open again to see what I got going on Now!
ntimad8.cz28.com
Old Jun 14, 2002 | 09:55 PM
Z_Ghost's Avatar
Post
Oil temp.
More important than water temp.
Old Jun 14, 2002 | 10:40 PM
kandied91z's Avatar
Post
you should only have guages for what your going to use.......
seeing as how they vary on each setup it will make a difference.
although if i was running N2O or a blower i would definately want the fuel pressure an some type of air/fuel ratio guage! i've heard the trans temp is an important guage as well so you might want to look into that.
boost pressure as well as N2O pressure are a given when running those setups so that's at least 3 for sure.
Old Jun 15, 2002 | 01:46 AM
Stephen 87 IROC's Avatar
Post
The stock gauges are not highly accurate.
Fuel pressure is nice however you can't have a fuel line inside the car. It will either have to be an electric gauge or a mechanical one with a fuel isolator on the firewall.
Since you're relying on factory gauges for most of the important things there's not much left you actually need a gauge for.
Tranny temp is inportant especially if you have a converter that's higher than stock.
Engine oil temp is nice but not really needed since it should be a little lower temp than the coolent.
A vacuum gauge hooked to the intake manifold is nice to have.
I only have 6 gauges in my race car. 7 if you count the tach.
Oil pressure
Tranny temperature
Engine coolent temperature
Voltage
Crankcase boost/vacuum gauge (I run a vaccum pump to the crankcase)
Pyrometer (tells me how hot the exhaust is)
OK I lied. I have another gauge. I have a mechanical fuel pressure gauge mounted on the cowl under the hood scoop.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.603
Best MPH on a time slip: 115.6
Best corrected ET: 11.138
Best corrected MPH: 121.85
Altitude corrected rear wheel HP: 450
Best 60 foot: 1.671
Member of the Calgary Drag Racing Association
[This message has been edited by Stephen 87 IROC (edited June 15, 2002).]
Kris93/95Z28
Jan 8, 2007 01:07 PM
formulafirehawk
Parts Wanted
Mar 24, 2006 12:09 PM
