Got a problem with a Z28 at a friends speed shop. Need your opions
Old Apr 17, 2003 | 08:39 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
They put on a set of long tube headers and then took it for a drive. Any thing below 3,00rpm's and the car misses really bad, but once you go above 3,000rpm's it runs nice a smooth. They replaced the plug wires and still does the same thing. Then they called me to see what I thought it might be?? I took the car out. Misses like crazy below 3000, but just past that and the car pulles strong. I'm thinking opti here. Mine did the same thing, but on the top end. What do you guy's think. we put my Mass air meter and coil on the car and it still did the same thing.
My vote is for the opti.
Neal
Old Apr 17, 2003 | 08:43 PM
WhiteThunderZ28's Avatar
might be oxygen sensors ???
Old Apr 17, 2003 | 09:03 PM
dreamer1q's Avatar
Possible they cracked a plug?
Q
Old Apr 18, 2003 | 01:05 AM
BigBlue95Z's Avatar
It could possibly be the EGR valve. If i'm not mistaken, the EGR is not used at RPMs above 2800. Just a thought.
Old Apr 18, 2003 | 09:16 AM
donot_4get's Avatar
I had a similar problem
I changed the wires, and then the opit and I still had the missfire....
it finish being a cracked a plug (felling dumb)
leo
Old Apr 18, 2003 | 09:18 AM
Rodrigues's Avatar
Make sure they got the firing order on the opti correct
http://csce.uark.edu/~jgbertr/rb/opti.jpg
Old Apr 18, 2003 | 12:38 PM
ZPaul2Fresh8's Avatar
Longtubes with emissions? They don't mix... I mean mine don't have emission hookups on them (Dynatech). My vote is for checking those plugs. Make sure the wires aren't too close to the headers.
Man 1 more day and I'll be on a weeks vacation...too bad my car just got painted and it still needs wetsanded!
Old Apr 18, 2003 | 01:25 PM
BigBird's Avatar
My car did the same thing and it ended up being the 02 sensors. You might need to replace them with sims.
Bruce
Old Apr 18, 2003 | 01:28 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
your wires are burnt out on the headers
Old Apr 18, 2003 | 02:22 PM
93Z286Speed's Avatar
i really dont think its the opti here at all. Cracked Plug seems logical, as does burnt wires and O2's. Id check those 3.. very easy to replace, so its not a huge deal
Old Apr 18, 2003 | 03:54 PM
PNYKILR's Avatar
Trey, they put new wires on, and still the same thing. I'll tell them to check the plugs,egr,o2's. It's amazing what can happen when doing a simple header job. I've done it about ten times and never had a problem. I guess they should have had me do it.
Just checked in with them. Plugs are brand new and is still doing it.?????
Old Apr 18, 2003 | 05:11 PM
1FASASZ's Avatar
you want something done right you gotta do it yourself
Old Apr 18, 2003 | 05:34 PM
treyZ28's Avatar
doesn't matter how new they are if they are grounding on the headers
rideordie
Nov 5, 2019 04:52 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
siguy
Nov 27, 2014 10:07 AM
