Got My Trouble Codes Finaly
Old Jun 18, 2004 | 10:18 PM
glennxx1's Avatar
48 36 22 42 i just changed my MAF a week ago
Old Jun 18, 2004 | 10:31 PM
glennxx1's Avatar
and does any1 have a site or a chart/table with the numbers all the sensors etc shold be? my MAP was only .32 i think its suposed to be a bit higher isnt it?
Old Jun 18, 2004 | 10:38 PM
MAP at idle with a stock cam should be about 1/3 of barometric pressure.... 32kPa doesn't sound bad.
Shoebox has the code chart on his Tech Pages:
http://shbox.com/1/Dtcs.htm
22 = TPS sensor voltage low
36 = Opti high resolution signal faulty
42 = Ignition circuit shorted or grounded
48 = MAF sensor circuit
Are you sure you didn't pinch a wire bundle, or lose a ground strap?
Old Jun 18, 2004 | 10:47 PM
glennxx1's Avatar
were would i find a pinched wire or bundle? i havnt done anything lately so i dont think i have, but tell me where i should look
Old Jun 19, 2004 | 07:11 AM
glennxx1's Avatar
maybe it was a old air/egr wire i unpluged some where? (removed that stuff in header isntall)
Old Jun 19, 2004 | 07:48 AM
n2ceptor's Avatar
Did you reset your PCM aftr the install.... Ie: remove the fuse in the dash marked PCM BATT or neg battery cable.... To allow the computer to relearn....
Old Jun 19, 2004 | 09:53 AM
glennxx1's Avatar
let it relearn what...that egr/air was gone/ teh batt wasnt connected when it was removed
Old Jun 19, 2004 | 07:36 PM
glennxx1's Avatar
and grounding ignition wire, is that a spark plug wire or... any wire?
Sauced
Apr 12, 2015 10:18 AM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
