Got My Trouble Codes Finaly
MAP at idle with a stock cam should be about 1/3 of barometric pressure.... 32kPa doesn't sound bad.
Shoebox has the code chart on his Tech Pages:
http://shbox.com/1/Dtcs.htm
22 = TPS sensor voltage low
36 = Opti high resolution signal faulty
42 = Ignition circuit shorted or grounded
48 = MAF sensor circuit
Are you sure you didn't pinch a wire bundle, or lose a ground strap?
armedtrigger
Feb 24, 2015 08:30 PM
