Got LT4 heads, WHAT CAM
Old Sep 13, 2003 | 12:29 PM
  #16
T/A KID's Avatar
NO the 650 bucks is shipped, the heads are bare, so I need to add valves (thanking about Manley) and I need to buy the intake, I think its like $215 from GM (I like those red intakes ).
My mechanic friend and I are going to put on everything on at once. Cam kit, 1.6 RR's Heads, intake, LT4 ED timing chain, and PCmforless programming.
Going to go FAST, lol
Old Sep 13, 2003 | 03:12 PM
  #17
Camaro_Maniac63's Avatar
My vote goes to GM 847. should work well with those heads.
Old Sep 13, 2003 | 03:14 PM
  #18
black93's Avatar
what cam
if i were you i would go with the lt4 cam set it is a great package i just picked mine up. The LT4 cam is a good HP and power adder cam to work with
Old Sep 13, 2003 | 03:20 PM
  #19
Z95m6's Avatar
i would go with a bigger cam like the 230/236 if you are planning on doing all this heads swapping and plan for big heads later. Why not just buy one cam.
Old Sep 13, 2003 | 03:52 PM
  #20
GM 847= 234/242 575/595 112lsa
Old Sep 13, 2003 | 05:38 PM
  #21
mikeRv6's Avatar
I have a set of mildly ported LT1 heads that prob flow about the same as LT4 heads. I installed the cc306. I dont like it, its to much cam. Since the cam wants more air then the heads can give, im not getting the kinda of power i should, and my driveablitly sucks. I have since learned the value of a cam that is well matched to the heads. Im putting my stock cam back in and im gonna start jucing it. Pleanty of power at the track when i want it, and no drivablily or gas losses.
Go with a cam like the 305. Get one custom ground with higher lift if you can afford it. Dont go huge because the power wont be there without more porting. Even if you are gonna port the heads out more later, dont get a big cam now. Cams are easy to swap if youuve already got the heads off. Huge cams are cool to drive around for the first few months, or only on weekends in light traffic, but if you drive yours everyday like i do, you'll get sick of it fast.
Old Sep 13, 2003 | 06:05 PM
  #22
K!D's Avatar
K!D
I have the 306 cam, and I like it. Though when I had ported stock heads I had 415rwhp/ 378rwtq I am planning on porting the LT4 heads
Old Sep 13, 2003 | 06:26 PM
  #23
Blk94Z28LT1's Avatar
i'd go with the LT4HotCam
Old Sep 14, 2003 | 01:40 AM
  #24
PhoenixCIS's Avatar
i went with the 230/236 .544/.555. it should be good for when you get the heads ported. i should have dyno numbers sometime this week or next. i get my car back this week
Old Sep 14, 2003 | 07:06 PM
  #25
T/A KID's Avatar
I believe I am going to go with the CC305. Does anyone know where I can get this cam in a KIT
Old Sep 14, 2003 | 07:52 PM
  #26
simple's Avatar
http://web.camaross.com/forums/showt...hreadid=168554
give those guys a call, you will not be disappointed!
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
Queens94z28
Nov 20, 2014 06:03 PM
GigaMp3z
Feb 20, 2003 02:57 PM
