Good source for lt4 hot cam and is it worth it?
Old May 11, 2019 | 09:43 AM
Darrenmb's Avatar
Hi all, currently rebuilding 94 lt1 to swap into my jag xj6, dont want to go nuts on the build, just want a bit more torque as the jag is heavy, I'm using the stock lt1 aluminum heads with lt4 springs, and might be able to get away with some block hugger headers as clearance to steering rack is limited, if they wont work I will have to use ram horn manifolds. Not ideal I know, but choices are limited..
Sooo. Is a hot cam going to help? What's best source? I have found it on summit for 300. Same price at Chevrolet. they both state it needs dowel pushed in and has a fuel pump lobe.. am i looking at right one?
Darren
Old May 11, 2019 | 02:34 PM
Chimera96's Avatar
Re: Good source for lt4 hot cam and is it worth it?
I would suggest you contact Lloyd Elliott and get one of his cams. It may be $50 more than that Hot Cam....but be better.
The Hot Cam is more a higher RPM cam for the lighter F-body car, not a torque cam
The LT4 springs are "barely" adequate for a LT1 as the LT1 heads have solid, heavier, valves than the LT4 which had sodium filled "lighter" hollow valves. If you are using any can other than a stock LT1 cam the LT4 valve springs are just not enough
The Crane 10308 would be way better but there are other choices.
95TALT1
Mar 5, 2018 08:06 PM
ChevyCH53
Parts Wanted
Apr 4, 2014 11:55 PM
hambone3441
May 10, 2012 01:06 PM
Johnnynsac
Jan 1, 2004 08:57 AM
19WS6T/A91
3rd Gen / L98 Engine Tech
Jan 27, 2003 06:37 PM
