good rockers?
Old May 6, 2004 | 02:57 PM
Heatmaker's Avatar
Advanced Member
good rockers?
heyfolks, whats a good set of rockers to use with an agressive cam? 1.6's .... ALuminum or that other stuff? prices?
Old May 6, 2004 | 02:59 PM
Red96Lt1's Avatar
Go steel if you can afford it.
Old May 6, 2004 | 03:01 PM
Dave Feerst's Avatar
use 1.6 ratio and use a roller. most people use alumnium LT-4 (same as crane 1.6 gold alumnium rockers). or comp cams.
Crankshaft's Avatar
Pro Mags.
Old May 6, 2004 | 03:02 PM
Pasky's Avatar
Go steel if you can, Thier usually lighter and will outlive the aluminum roller rockers. The aluminum material may be lighter but they need to make it wider I think which causes them to be heavier.
Old May 6, 2004 | 03:33 PM
Heatmaker's Avatar
Advanced Member
Cool....thanks guys!!!!!
What manufacturers do you guys reccomend?
Old May 6, 2004 | 05:20 PM
12SCNDZ's Avatar
COMP Cams "Pro Magnums"!
Frank
Old May 6, 2004 | 05:22 PM
jkipp84's Avatar
Comp Cams Pro Magnum chromoly 1.6 Non-Self Aligning.
Check out the Supporting Advertiser Index for shops that sell them..
Old May 6, 2004 | 07:06 PM
rskrause's Avatar
Moderator
Nothing wrong with a good set of aluminum roller rockers as long as you aren't using a stout spring (as in a solid lifter setup).
Rich Krause
Old May 6, 2004 | 08:20 PM
"White Knight"'s Avatar
Anybody know typical HP gains for a set of good roller rockers? I am considering some also, I am thinking comp cams magnums like stated above.....little pricey but you get what you pay for
Old May 6, 2004 | 08:30 PM
Mindgame's Avatar
"Gains" always vary, so there isn't a concrete answer. Just know that there are "gains". Some from a reduction in friction, some from more accurate valve timing/lift as compared to stock stamped rockers.
Anything that helps reduce friction, accuracy, etc. is worth a gain. Don't get too hung up on numbers.
In regards to the "brand" question. I like Comp, Isky and Harland Sharp for stud mounts.
-Mindgame
oldschool
Feb 9, 2016 09:21 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
