Golen 383 - Are new Flexplate / Dampner necessary?
Old Dec 3, 2010 | 08:20 PM
  #16
95TA04GOAT's Avatar
Re: Golen 383 - Are new Flexplate / Dampner necessary?
When i put my golen 383 together about 5 years ago I bought a flexplate from them. It looked like they had just cut the balance weight off a new stocker. I didn't mind, at the time i didn't have the skills or tools to do it myself and it was cheap enough for a new one that i knew was going to work. I was never advised to put a keyed hub on and never had a problem.
Old Dec 6, 2010 | 02:16 PM
  #17
PWR SHFT's Avatar
Sorry, Rich. I am going to disagree with you on this one...
You do NOT need a keyed damper on an LT1.
The woodruff key was not intended to keep the damper from spinning. It was originally used to align the old school dampers that need a timing reference mark. Since LT1s do not use timing marks, it is not needed. It was also used on the 400SBC to make sure that the balancer was in the right position. The 400 was externally balanced at both ends and had a special balancer with a counterweight instead of a traditional damper.
It is the interference fit is what keeps a damper from spinning. Now, with supercharged engines, this does not apply. They need a keyway to prevent to load on the balancer from spinning it. A single keyway is not usually sufficient so they use a double key set up.
I speak from experience here. I had an old BBC that I replaced the crank in and the machine shop took off a little too much off the snout when they polished it. The balancer went on a little too easy. After a few (dozen) hard shifts, the balancer ripped out the keyway and gouged the end of the crank and almost spun off.
Again, Interference fit is the key.
Old Dec 6, 2010 | 02:22 PM
  #18
rskrause's Avatar
Moderator
I just see the key as a little "insurance" with no downside.
Rich
Old Dec 6, 2010 | 03:26 PM
  #19
PWR SHFT's Avatar
Rich
That I can agree with.
Old Dec 6, 2010 | 03:33 PM
  #20
pizzi-man's Avatar
Originally Posted by aaron_depue
Recent purchase a Golen 383. Golen recommends a new " neutrally balanced" flexplate and a new "keyed" dampner. Are these new parts necessary? Or is modifying my OE flexplate and dampner a cheaper and equally as effective bet? Should a machine shop have any issues keying a OE dampner to fit? What about removing a weight and balancing an OE flexplate? Looks like an opportunity to save a litle bit of money but I wana make sure Im not missing out on some cheap insurance by neglecting to purchase recommended parts...
I had a new flex plate balanced when the machine shop was balancing the crank. They didn't take much off the flex plate but I am assured that it's netural balance. I also replaced the dampner at the same time. I personally would not use the originals with 150,000 miles on a new motor.
Old Dec 8, 2010 | 07:25 AM
  #21
aaron_depue's Avatar
How much did balancing a flexplate cost at your machine ship? New ones are oly like $100 from Golen. Thanks for the input so far. Im learning alot...
Old Dec 8, 2010 | 01:41 PM
  #22
pizzi-man's Avatar
Being I was getting the crank balanced they charged me like $ 10.00 extra along with repolishing the crank and giving me a bunch of assembly lube packets. If I remember correctly the flex plate cost around $55.00 new.
Old Dec 11, 2010 | 11:25 AM
  #23
It will probably be worth the money to buy a new on Im thinking... Hays sell a good one for like 85 bucks. Its stronger and you can get them balanced however you wish.
Old Jan 6, 2011 | 01:50 PM
  #24
2cub49's Avatar
Chad sells a keyed hub you can bolt your stock damper to.
I think it's about 100.00.
RUENUF
Mar 13, 2016 03:37 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
