Oil Leak. Help!!!!!!!!
Old Jan 5, 2011 | 05:32 PM
meangreenchevy's Avatar
had my new motor in for 200 miles no leaks. car went to the body shop for a hit and run on the rear bumper(not major damage). now i picked it up and its leaking oil all over from the passenger side lower part of the motor. its seems to be leaking from right behind the passenger side motor mount. whats over there besides the oil dip stick that can leak?
Old Jan 5, 2011 | 06:10 PM
RamAir95TA's Avatar
Re: Oil Leak. Help!!!!!!!!
Valve cover is the first thing that comes to mind. Could also be the rear intake manifold seal, dipstick, oil pan, rear main seal, timing cover seals, timing cover gasket, etc.
If you still can't figure it out, a dye kit would work wonders.
Old Jan 5, 2011 | 06:13 PM
it wasent leaking from the valve covers i checked that that. could the intake leak make it from the back of the motor to the middle?
Old Jan 5, 2011 | 06:27 PM
RamAir95TA's Avatar
I've seen when an LT1 leaks oil it gets EVERYWHERE. So I wouldn't rule it out!
Can you post a pic?
Old Jan 5, 2011 | 06:59 PM
i cant my jack is buried under snow as you know from our east coast snow storm. and you really cant see it from up top
Old Jan 5, 2011 | 08:57 PM
moparman's Avatar
Stick your hand behind the head on the passenger side. Move your hand around the back of the head, the intake, and down the block. Oily hand, probably the intake leak.
Old Jan 6, 2011 | 11:28 AM
Z28SORR's Avatar
The power steering is on that side and has a plastic reservoir, that could have cracked in the accident. Might be worth checking.
Old Jan 6, 2011 | 05:59 PM
the scratch was on the rear bumper. and its def not the intake leaking. stuck my hand back there and its bone dry
Old Jan 6, 2011 | 06:21 PM
moparman's Avatar
You may have to get some dye and a light and search for it that way. NAPA has the kits.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
