Going to burn my LT1, who's with me??
Old Jul 11, 2003 | 11:00 AM
  #31
TMD95Z28's Avatar
i just installed shorties headers and wires, works great... i love my car more than ever..
oh and sorry about the bad luck with the lt1..
Old Jul 17, 2003 | 12:11 PM
  #32
thefox1's Avatar
Well, went to the dealer and they say it's the opti again, I'm thinking great cause it's still under warranty. It didi'nt take long for my great to change to SH*T!!!!!!Last time all they changed was the cap and rotor, not the whole opti!!! So now to purchase the bck of it, it comes with the cap and rotor so they want anopther chunk of money to change it!!!!!!!!
Old Jul 17, 2003 | 12:38 PM
  #33
BlownF1's Avatar
Wow, that's a bummer...was it a GM dealer? I didn't realize they would/could even change just the cap/rotor. Be sure to check your receipt to verify. Good luck!
Old Jul 17, 2003 | 12:50 PM
  #34
DR.ZED's Avatar
I can say with confidence, I have one of (there are higher), the highest mileage 94 Z28s out there.
270,000 kms.
Still on original fuel and water pump.
I track the car, I drag the car, I have fun on the street with the car.
I rebuilt the motor, because of a spun rod bolt (long story, not an LT1 issue).
2 year old opti, non-vented. MSD over the valve cover wires, TR6 plugs. The car has left me stranded, ONCE because that was my fault. I took a garden hose to the opti (I was such a noob then). My started died at 160,000 kms, and I push started it.
Also, the clutch went, because a sh!tty pilot BUSHING was used from a jobber.
Do regular oil changes, keep up on your coolant changes, put a new rad cap on every 100,000 kms...
... also, learn about the engine. You cannot expect it to run perfect, if you're not taking it to somebody who knows the electronics and quirks about the car.
Old Jul 17, 2003 | 12:51 PM
  #35
thefox1's Avatar
yeap, they can change only that! When I asked another dealer they said they could'nt, but after finding the part # on the bill the found out the part exists.
Old Jul 17, 2003 | 01:46 PM
  #36
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Originally posted by thewinner
Im down for it. See sig.
how is the LT1 at fault? you ****ed it up and you cant install a cam. suddently its all the LT1's fault. The bed in my truck is kinda banged up after i dropped a TV in there- what a POS motor they gave me
Originally posted by notstock4long
I'm with you. I seriously wish I never would have bought my car. It is the worst choice I have ever made. I just put a new engine in, then it overheats all the time, and now the starter dies a week later.
Again, its not the engine. you just need to find out what u skrewed up. The LT1 doesn't have an overheating flaw in the design
As far as the original poster-
you engine builder sucks if you oil pressure keeps going all over the place at idle. again, 99.999% of people dont have this problem. you get your motor rebuilt then blame it on the design of the motor as to why its not running right?
If its static under load and idle your pickup fell off, your low on oil and/or too much clearance b/t the bearings.
Old Jul 17, 2003 | 02:14 PM
  #37
thefox1's Avatar
actually, I'm not blamming the Lt1 for the troubles, if you read my post correctly you'll find that I blamme garagist who don't know hot to work on the LT1 bc not every garagist gets to work on them on a regular bassis, thus my request for finding help on how to determine if a garagist knows what he's talking about.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jun 23, 2016 08:42 PM
blac94Z
Jan 12, 2015 05:44 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
