Going to burn my LT1, who's with me??
Old Jul 9, 2003 | 06:08 PM
thefox1's Avatar
No but seriously, thiss car is driving me broke!!! I'm in a tad over 4 grand in engine repairs in less than a year and still have problems. My engine was rebuilt a month ago bc of a bad knock in the crank, in March I had opti, wires, plugs, ICM ignition coil replaced. Guess what, I'm still having problems!!! The engine ran perfectly fine for a month after the rebuilt and now is running weird. When I've been driving for about an hour, on iddle the engine bounces around (500rpm up to 2,000rpm), and then has no power to accelerate until higher in the rpm range (3-5k rpm) it feels like it's about to choke. Any ideas on what the problem is or how to select a good mechanic who knows what he's talking about when working on a LT1???
Old Jul 9, 2003 | 06:30 PM
CoronaL's Avatar
disconnnect the O2's and see if that helps
could be o2 sensors or MAFS
but wtf do I know
Old Jul 9, 2003 | 09:05 PM
thefox1's Avatar
but wtf do I know
If the o2 is the cause, would'nt disconnecting it give the same problem if already ai'nt working?
Old Jul 9, 2003 | 09:09 PM
Kris93/95Z28's Avatar
The best Idea would be to have it scanned with TTS or a program like that and go from there.
Also you may need to Check out your IAC.
Old Jul 9, 2003 | 09:19 PM
jasons93z's Avatar
i love my lt1
Old Jul 9, 2003 | 10:41 PM
atljar's Avatar
I hate my car too, but at least i have (in my opinion) one of the best lt1 specific guys working on it for me. Just sucks that i installed my cam myself,
Old Jul 9, 2003 | 10:44 PM
thewinner's Avatar
Im down for it. See sig.
Old Jul 9, 2003 | 11:20 PM
notstock4long's Avatar
I'm with you. I seriously wish I never would have bought my car. It is the worst choice I have ever made. I just put a new engine in, then it overheats all the time, and now the starter dies a week later.
Old Jul 9, 2003 | 11:29 PM
thewinner's Avatar
i wish i would have kept my car stock and just built a race car....honestly.
Old Jul 10, 2003 | 08:25 AM
CoronaL's Avatar
but wtf do I know
if the o2's are the prob and you disconnect them the car will go into startup mode and not run off the O2's but more of a dummy program in the startup table. At least from my limited knowledge of this stuff
Old Jul 10, 2003 | 08:58 AM
CARGASM's Avatar
sounds like a MAFS problem...have it scanned.
Old Jul 10, 2003 | 09:08 AM
2hipbiker's Avatar
could be MAF but dunno about that, disconnect it and if thta helps then u kno thats it, you need to have ur coil checked and ur opti tho, i know that you said they are new but it doesnt mean a darn thing... i had a new opti put in and less than 2k later it was toast again... as for coil.. i put a new coil in b4 and it worked for about 2 months then went bad that fast and my mechanic told me that it happens fairly often hope some of that helps
Old Jul 10, 2003 | 09:16 AM
thefox1's Avatar
tnx for the info, the opti should still be under warranty if I ake it in to be checked, I'll have a look into that.
Old Jul 10, 2003 | 09:32 AM
BlownF1's Avatar
Don't rule out the easy one...plug wires, not uncommon especially after a rebuild if they didn't get everything back in the right place.
Old Jul 10, 2003 | 09:37 AM
bruecksteve's Avatar
What did you change with the new engine? Did you re-program the pcm???
