going back to stock tb-any problems
Old Dec 24, 2009 | 08:47 AM
Dwaynez28's Avatar
Question going back to stock tb-any problems
Hello, after a couple of years with the shhhh sound of my BBK 52mm tb i want to go back to my airfoiled stock tb-want to see if this will correct some minor issues im thinking im having--question is-this car was mail-order tuned with the 52mm tb--am i creating a problem going back to my stocker since the car was tuned with the 52mm tb? thanks Dwayne
Old Dec 24, 2009 | 09:40 AM
bw_hunter's Avatar
I wouldn't think you'd see much difference at all. Theoretically, if you did see at issue it would be at high rpm where the engine needs the most air.....
Old Dec 24, 2009 | 10:14 AM
May have a minor affect on the shift points of your A4. Other than that, you shouldn't notice a difference.
Old Dec 24, 2009 | 11:04 AM
Dwaynez28's Avatar
thanks Dwayne
Old Dec 25, 2009 | 05:27 PM
Biggriff's Avatar
whats the plan 4 the 52mm tb....
Old Dec 25, 2009 | 07:49 PM
Dwaynez28's Avatar
for right now its sitting on toolroom shelf in case i get a wild hair and put it back on--today--Chritmas day i did the swap-so far no ses light( im good for getting one)--might/probaly imagination, but test drive it didnt seem quite as peppy--i know smaller tb--giving it a few more days to let me and the computer adjust--i bought a new tps for the swap-so i can just bolt it right up when i want to--dwayne
Old Dec 27, 2009 | 12:50 PM
2QUIK6's Avatar
I actually thought throttle response was much better after going thru a BBK and then a Holley TB and then finally said screw it since no one seems to make a TB that performs as well as the stocker and has the correct iac passages...had tried numerous mods to fix them them both..BBK wouldn't idle right since there were no IAC air passages...Holley had same issue but there was a way to create one, then the blades wouldn't close completely as the return spring was too weak..fixed that and still didn't seem to operate as smoothly and act as responsive as the stocker...didn't give up any hp on the dyno with a GTP6 cam at the time so I know its not giving anything up with the smaller cam in there now.
Old Dec 27, 2009 | 01:49 PM
Dwaynez28's Avatar
Wink
yeah after going back to stock on christmas day, i think i may have lost some throttle responce-but im staying stock now to see if some issues get better-like a little rich condition-hadnt notice it as bad now with my stock tb, but still looking to see if it actually has help or if the wind is just blowing in a different direction--of course on the 52mm tb the tps could be off too--just playing around now- Dwayne
Old Dec 27, 2009 | 04:09 PM
The smaller bore takes more blade rotation to achieve the same open area. Just feels like you have to move your foot more to get the same results.
DirtyDaveW
Dec 1, 2016 05:37 PM
Jlo
Feb 3, 2015 09:41 PM
Catmaigne
Dec 25, 2014 12:16 PM
MJ_Z28
Aug 8, 2002 09:07 PM
