gm847 rev/dyno question
Old Jul 16, 2007 | 06:17 PM
taubr unit's Avatar
I got a 847 cam in my car with stock heads (for now) and wondering what i should set my shift points for. Right now madz28 set the shift points for 6900 and im pretty sure thats too high for stock heads to flow. And it would be poitnless to rev to the moon and not make any power. Who has dynoed this cam on stock heads and where does the power start to fall off??
Old Jul 16, 2007 | 08:05 PM
atljar's Avatar
Thats way too high. Here is my old car with stock heads and 847
http://home.cinci.rr.com/atljar/atlj...Heads%20NA.jpg
Old Jul 16, 2007 | 09:14 PM
My Iroc Z28's Avatar
My cam pulled to 6500 shifted @ 6800 with a m6 6900 might be to high but the only way to tell is to put it on the dyno
This is the only internet ready graph i have it before it was tuned might be hard to read but it's something
taubr unit's Avatar
356hp, thats pretty good. what supporting mods do you got with that too? So its looking like 6200 is the peak power, im gonna need to change this thing bad.
Old Jul 17, 2007 | 09:32 AM
Z-RATED94's Avatar
Are you sure that's where the shift points are? Or is that where he set the rev limiter?
Old Jul 17, 2007 | 04:22 PM
CamaroSS30thAnn's Avatar
that has to be the rev limiter.
Madz would never set the shift point that high on a stock headed car with a GM847
Old Jul 17, 2007 | 07:32 PM
atljar's Avatar
Everything possible + a 12 bolt
Old Jul 17, 2007 | 07:59 PM
SS RRR's Avatar
[/IMG]
You would've been better off shifting much earlier since your peak was ~5600rpm. Shifting long after your power peak slows you down.
Old Jul 17, 2007 | 08:14 PM
That was before a correct tune was installed, after the tune was adjusted the power band shifted and it peaked around 6400 with no fall off we figured with my shifting abilitys it was best to shift it around 6800 to keep it in the correct powerband.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
LT14LIFE
Feb 9, 2015 09:35 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
