Only getting 21MPG Highway, suggestions?
Old Jul 10, 2007 | 02:35 PM
The Captain's Avatar
I checked my millage, and I am currently getting around 21MPG strictly highway, so you can imagine what mixed city and highway is. All I have done is a cutout that is always open, and one of those cheap cone air filters from autozone. Car is bone stock. Any suggestions to get this thing running better? It just turned 40K miles.
Old Jul 10, 2007 | 02:56 PM
LSWHO's Avatar
See if your cheap cone air filter is clogged.
Do a basic tune up.
Go to a different gas station.
Old Jul 10, 2007 | 03:02 PM
mthegodfather's Avatar
LT1's are thirsty.....
Old Jul 10, 2007 | 03:07 PM
JakeRobb's Avatar
Super Moderator
A4 or M6? If it's an A4, your converter might be worn out.
Old Jul 10, 2007 | 03:56 PM
Mortify's Avatar
Hmm I would seafoam it if it had more mileage... I would check filter and maybe clogged cat aswell (if cutout is after cat) ... what do you get with cutout closed?
Old Jul 10, 2007 | 04:35 PM
n2ceptor's Avatar
You have the same car/color as mine.... I got my 93Z w/A4 at 54000 miles and had 24 MPG highway stock....
Now with 139,000 miles, I get 22 MPG highway, w/cat back, G2 CAI, and 1.52 rockers with regular maintenance....
Maybe O2 sensors????? Original plugs?????
Old Jul 10, 2007 | 05:01 PM
ZL1modified's Avatar
aside from the mileage does it run bad or seem to be running rich...
Old Jul 10, 2007 | 05:57 PM
micfly83's Avatar
I get about 12 in the city and about 17 mixed, and 22 or so on the highway
Cutout and K&N
Old Jul 10, 2007 | 10:46 PM
JakeRobb's Avatar
Super Moderator
Cutout and K&N
Holy crap! I know LS1s get slightly better mileage than LT1s, but you should be doing a lot better than that. I get 18-20 in the city, ~22 mixed, and 27+ highway.
Old Jul 10, 2007 | 11:10 PM
micfly83's Avatar
I really dont know what the problem is
My daily commute is about 2 miles, so theres a lot of starting and letting it warm up and the occasional punch of the gas everyday.
And revving towards the ladies on campus now and then.
Old Jul 11, 2007 | 12:03 AM
Ironxcross's Avatar
i get 26 mpg highway (im an m6, but still). ive gotten up to 29. City is normally 16 (thats alot of stop and go and time at lights) and mixed is around 20.
Old Jul 11, 2007 | 12:10 AM
plaf713's Avatar
be happy with 22mpg, if you think about it, its a 350 knocking down more then 20 mpg.
Old Jul 11, 2007 | 06:21 AM
JakeRobb's Avatar
Super Moderator
That's a ridiculous suggestion, when others with essentially the same car are getting so much better results.
Old Jul 11, 2007 | 08:30 AM
JakeRobb's Avatar
Super Moderator
Originally Posted by Z28Roxy
I hit 29 mpg in my LT1 when it was an A4!
I usually drive too fast for that. Plus, you had a shorter gear ratio.
Old Jul 11, 2007 | 11:41 AM
No o2 sensors on the 93s, it is an A4 and shifts perfectly, car runs fine, it will get up and go with no hesitation or anything. As far as I know, it still has the factory plugs and wires. It is throwing a code 26, which is the EVAP system, but I wouldnt think that would hurt fuel economy too much The cheap cone air filter looks like it could use a cleaning, but its really not that bad.
