Gm847
Old Aug 8, 2006 | 10:40 PM
976speed's Avatar
Gm847
Will a GM 847 work with stock heads and if so, what all will i need to do the cam change. What kind of price range will i be in and what track numbers will i be into with long tubes the cam, 58mm tb, MAF, CAI, drag radials and 4.10s with a 6 speed?
Old Aug 8, 2006 | 10:44 PM
Javier97Z28's Avatar
Moderator
Re: Gm847
Figure about low 12's with a 6speed and a 10 bolt.
If it was an A4 car I'd say 11's, but there's only so much a 10 bolt can take behind a 6spd.
Old Aug 9, 2006 | 09:31 AM
My Iroc Z28's Avatar
Re: Gm847
figure around $1200 For the cam & all supporting valve train upgrades, Then you will need new gaskets, fluid, plugs, Opti (recommended Not needed) Then a tune of coarse. I say by the time it's all over with about $1800 in parts (new) but things can be found cheaper used if you go that route.
My Times are below.
LT14LIFE
Feb 9, 2015 09:35 PM
med_reject
May 17, 2004 05:33 PM
nhodge93
Apr 6, 2004 05:42 PM
nhodge93
Apr 1, 2004 02:39 PM
AdamZ1LE28
Mar 18, 2004 04:20 PM
