does gm847 need such tight springs??
Old May 17, 2004 | 05:33 PM
med_reject's Avatar
One of the threads stated the requirements for gm847 springs:
Spring Requirements:
Loads - Closed 115 LBS @ 1.750 or 1 3/4"
Open 336 LBS @ 1.210"
That doesnt seem like very much, yet everyone who runs these cams seems to want kmotion k800s or crane 99893s.
If the above specs are correct, then the k-750 should also work with the gm847 and 1.6RR, and be easier on the lifter, pushrods, retainers, etc.
1.265'' diameter single H-11 spring. Valve lift up to .610''. 130# @ 1.700'' closed, 380# @ 1.150'' open, coil bind @ 1.030''.
Im I missing something? maybe these are not good for high rpm? Im not an expert on valve springs, any articles or info would be appreciated.
thx
Victor Lamb
Aug 26, 2017 02:52 PM
sseeya
Apr 9, 2015 06:38 AM
ChrisFrez
Mar 29, 2015 09:43 PM
LT14LIFE
Feb 9, 2015 09:35 PM
