Gm847
Old Nov 24, 2005 | 10:34 PM
  #16
TruDualed95Z's Avatar
Re: Gm847
if youre just wanting a big lopey sound, you can go with a smaller cam and just tune the idle down.
Old Nov 24, 2005 | 10:48 PM
  #17
My Iroc Z28's Avatar
Re: Gm847
Found it.... Maybe this will help you figure out whats best for you on the street.
http://web.camaross.com/forums/showt...&highlight=cam
Old Nov 25, 2005 | 12:10 AM
  #18
Capt'n Two Rotors's Avatar
Re: Gm847
I have a 95 cam only with the 847, 3k converter,3.23 gears and it drives like a dream, my next cam will be bigger, the 847 is very streetable and I have viturally no surge, if you take the time to tinker with it, you can get rid of the surge, I started with a pcmforless tune and went from there. From my experiace I am very happy and only wish I would have gone bigger but probably not much more left with stock heads, I think the 847 makes the most of the stock heads and is very street able. My best times are 7.89 at 89.62 with a 1.85 60', I have pulled some 1.79's 60's in crap weather so I think 12 flats or a high 11 isn't out of the question, this is also with a stock TB, I am getting a bigger TB and 4.30's so 11's should be cake after I get the suspension reset.
Old Nov 25, 2005 | 08:38 AM
  #19
Z284thgen's Avatar
Re: Gm847
my 383 ported LT1 castings gm847 made 400/415 through the 12 bolt and 28" slicks and went 11.06@122.8 with the 6spd
Old Nov 25, 2005 | 08:53 AM
  #20
calfirebird's Avatar
Re: Gm847
keep braging
this is the same cam i have i would say it you have a stock convertor you will have to upgrade to a higer stall. Other than that everything you listed sounds good but another good choice is the cc305 and 224-230 But there smaller more freindly in a smaller Ci motor like 350. Good price too.
LT14LIFE
Feb 9, 2015 09:35 PM
med_reject
May 17, 2004 05:33 PM
nhodge93
Apr 6, 2004 05:42 PM
nhodge93
Apr 1, 2004 02:39 PM
AdamZ1LE28
Mar 18, 2004 04:20 PM
