GM846 cam
Old May 10, 2010 | 01:27 PM
awill12's Avatar
GM846 cam
Where can i find this cam 222/230 - .543/.563 (Gm846). does anyone make of full kit for this cam like they do for the lt4 (Hot cam)? or will i just have to piece parts togther?. any tips would be great. Thanks.
Old May 10, 2010 | 04:42 PM
slomarao's Avatar
you wont find a kit. Also it isnt a popular grind and its old, ive seen it but that was a few yrs ago. Keep on finding F body speed sites and look, you'll find it sooner or later.
Old May 10, 2010 | 06:35 PM
bw_hunter's Avatar
Yes, an old grind but not bad if tuned properly with the correct supporting mods. That cam was made by Crane and I matched mine with a set of Crane springs and 1.6 ratio Crane golod roller rockers. I got a mail order tune and then followed it up with a solid dyno tune...I'm satisfied with the results.
Old May 11, 2010 | 09:17 AM
zcardriver22's Avatar
Those Crane Cams are getting pretty rare since they went under. You may have to search for awhile. Good luck
Old May 11, 2010 | 02:01 PM
awill12's Avatar
gm846
well i found the cam i just need to call them tomorrow and see what springs and **** i need. if any one else wants to no its at http://paceperformance.com/index.asp...D&ProdID=22579
thanks for the help
Old May 11, 2010 | 05:40 PM
bw_hunter's Avatar
thanks for the help
If you'd like some help from Crane's own catalog, go to www.cranecams.com and look up part number 109831. They have spring recommendations and a nice write up on how to select springs. I'd recommend the dual springs....
Old May 11, 2010 | 08:45 PM
slomarao's Avatar
I actually saw one in the FS section. I am not sure if it was here or LS1tech but look. The guy wanted 160 for it.
I never meant to say it was a bad cam by any means. I am pretty sure FrankZ held the cam only record with it right??
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
