this the gm 847 cam people are using?
12370847 Hydraulic Roller Design
This hydraulic roller design contains eccentric for mechanical fuel pump. It is for off-road use only. The duration at .050" tappet lift (intake/exhaust) is 234/242; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 539/558. Valve lash is zero/zero and lobe centerline is 112 degrees.
just wondering if this is the cam some lt1 people are using. thanks -dave
armedtrigger
Feb 24, 2015 08:30 PM
Z28Wilson
Aug 1, 2002 04:27 PM
