this the gm 847 cam people are using?
Old Mar 20, 2004 | 04:32 PM
chy20k1's Avatar
12370847 Hydraulic Roller Design
This hydraulic roller design contains eccentric for mechanical fuel pump. It is for off-road use only. The duration at .050" tappet lift (intake/exhaust) is 234/242; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 539/558. Valve lash is zero/zero and lobe centerline is 112 degrees.
just wondering if this is the cam some lt1 people are using. thanks -dave
Old Mar 20, 2004 | 04:34 PM
EviLZ28's Avatar
Yep, Thats the cam
Old Mar 20, 2004 | 04:36 PM
chy20k1's Avatar
what kinda rpm range do you get out of that? something like 3000 - 6500? thanks -dave
Klypto
Mar 23, 2016 09:05 AM
armedtrigger
Feb 24, 2015 08:30 PM
Z28Wilson
Aug 1, 2002 04:27 PM
