gm 847 with 10308 spring kit
Old Nov 1, 2007 | 03:15 PM
a4z28's Avatar
I was wondering if it would be okay to run the gm 847 cam with the crane 10308 spring kit . Cause i heard that u need 50' taller locks and that crane kit comes standard. Does anyone know a cheaper spring kit . thanks
Old Nov 1, 2007 | 05:37 PM
Bersaglieri's Avatar
Heard a few people running them with the GM847. Guys used to run the K-800's from K Motion, good priced spring.
-Dustin-
Old Nov 1, 2007 | 06:19 PM
truedualws6's Avatar
Do you have stock length valves? The 99893 springs are going to have
a closed pressure of 157# at 1.78" installed height. The +.050 locks or
retainers are a good idea. You also need to use a proper spring locator
with the 99893 springs. The 10308 kit only comes with shims which are
not worth a crap.
You have lots of spring choices but need to do some searching. If you
check the Crane site for the 847 equivalent cam which is the 109841 the
recommended spring is the 99846.
http://www.cranecams.com/index.php?s...&lvl=3&prt=122
Dec 1, 2014 08:08 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Don 97 SS
Jul 11, 2005 08:50 AM
97bowtie
Aug 25, 2002 11:00 PM
