Idle vid of H/C/I LT1
Old Oct 29, 2007 | 01:48 PM
urbaNHunter44's Avatar
Got my car running a few days ago. Here's her startup idle vid.
This is a Bret Bauer custom cam through open LTs. I should also say that I'm extremely happy with Bret's cam, very driveable and makes a ton of power.
Click here to watch MVI-0367
Old Oct 29, 2007 | 04:43 PM
96LT1TX's Avatar
nice, how loud is your valvetrain? and did you adjust the valves yourself? It seems like it is quieter than mine, and I have the LE3.2 cam.
Old Oct 29, 2007 | 05:17 PM
The valve train sounds like a sewing machine under the hood. It's very noticeable at idle. On my buddy's LE1 cammed car they sounded the same, louder than ****.
It's LS7 lifters, comp cams pushrods and comp cams pro magnum 1.6s. My buddy did the adjustments, however I feel that I'll need to readjust them soon since we did it without the lifters being pumped up.
Old Oct 29, 2007 | 05:29 PM
SS MPSTR's Avatar
An LE 3.257689 or ? without divulging BRE corporate trade secrets, what's the approximate or range of duration/lift @ 0.050" and what LSA? Do you plan to pass CA smog with it?
Old Oct 29, 2007 | 05:49 PM
OldSStroker's Avatar
From urbaN's website www.FQuick.com "(22x/23x - .6xx/.6xx - 10x LSA)"
Old Oct 29, 2007 | 06:27 PM
neil350's Avatar
Sounds good, how do you get around emissions out there?
Old Oct 29, 2007 | 07:07 PM
tiznodd's Avatar
The video doesn't do it justice. It sounds much more aggressive in person.
As for emissions testing, we have dyno smogs out here, which test the car under load at 15/25 mph. Big cams (within reason) clean up once they get a load placed on them and start turning a few rpms. With cats, I'm not so sure his car wouldn't pass. A few years ago someone passed locally with a 230/236.
Old Oct 29, 2007 | 10:36 PM
SS MPSTR's Avatar
Originally Posted by OldSStroker
From upbaN's website www.FQuick.com "(22x/23x - .6xx/.6xx - 10x LSA)"
who's upbaN ?
Old Oct 29, 2007 | 10:44 PM
who's upbaN ?
A [un]reasonable facsimile of the OP's name.
Old Oct 30, 2007 | 12:27 AM
yeah the specs are on my fquick. im really happy with it, didnt loose anything down low and pulls strong up top.
smog isnt really a problem, but i think it would prolly pass with a smog tune
Old Oct 30, 2007 | 09:14 AM
SS MPSTR's Avatar
This I'd like to see. Personally I don't think it has a snowball's chance in hell, regardless of tune. Assuming it is in the 108 LSA range, the car won't turn enough RPM to 'clean-up' on the smog dyno. Hell, 110 LSA isn't enough in a CC305. Very few 112 LSA cars, with reasonable durations, have passed. Good luck with that though - hopefully you have a 'hook-up' so it won't matter.
Old Oct 30, 2007 | 01:19 PM
87lt1rx7's Avatar
anything larger than mid 220s duration tends to push it at a smog station.but they may turn you away at the longtubes before it gets on the rollers anyways I am just speaking from experience
Old Oct 30, 2007 | 02:45 PM
SStrokerAce's Avatar
SS: I honestly really wonder why you are always fishing for cam specs from my stuff if my stuff doesn't run in your opinion? Probably just looking to drum up a pointless arguement like normal
urbaN: Cam sounds good! Glad you like it! It wasn't made for passing smog as one of the design requirements.
Bret
Old Oct 30, 2007 | 03:57 PM
SS MPSTR's Avatar
Yep - you got it. I want to copy your cam because everything they are in sets the world on fire. And we all know that the cams can be duplicated based on numbers at 0.050" too, right? I was curious to see if the lope the kids all drool over was anything more than a tight-*** LSA. I asked for a range anyway, not the specs, so relax.
Old Oct 30, 2007 | 04:39 PM
The "lope" is just a by-product of valve events that work, it's not a marketing sceme.
