GM 1.6rr clearance?
Old Jun 8, 2006 | 09:30 PM
LenT1's Avatar
GM 1.6rr clearance?
I did a quick search but couldn't find anything, just need a quick response if possible. Will the Crane 1.6rr that come with the hot cam kit clear stock valve covers? Thanks!!
Old Jun 8, 2006 | 09:37 PM
Another Red Z's Avatar
Re: GM 1.6rr clearance?
Yes , no problems at all.They were made for the center bolt valve covers.
Old Jun 8, 2006 | 09:46 PM
LT1_383's Avatar
I'm pretty sure clearancing is necissary for those as well. They were designed to fit under the LT4 composite valve covers which don't have the inner braces like the stock stamped steel ones.
I had a link to a page that explained and provided pictures for the clearancing required to get the rockers to fit but the site seems to have been removed. All I had to do with my valve covers to get comp pro mags to fit was flatten the braces with a pair of linesmen pliers and use channel locks to flatten the bafflel a little. It took about an hour and a lot of putting the covers on and off to check thef it.
Old Jun 9, 2006 | 07:49 PM
LenT1's Avatar
well it seems to fit by bolting on, but I dont know when everything starts moving if it will be hitting....?
Old Jun 9, 2006 | 08:21 PM
PostalZ's Avatar
I have some stock valve covers that are cut inside to clear 1.6rrs if you would like to pick 'em up. I bumped up to LT4s after my rebuild. They're nice, but i'm not sure the 5 lbs of corvette plastic i got is worth $275.
email me if you like. glladewig@new.rr.com
Z Power
Sep 19, 2015 11:19 PM
karpetcm
Sep 15, 2015 11:07 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
Aug 5, 2015 08:35 AM
