girdle
Old Jul 8, 2006 | 12:28 AM
slowpoke310's Avatar
girdle
is anyone using any main stud girdles on their rebuilds?
was their alot of altering involved?
im building a 383 lt1 converted to a 4bolt main, seems the girdle is going to require alot more altering than norm...
can i get away still with a stock oil pan?
Old Jul 8, 2006 | 11:27 AM
SStrokerAce's Avatar
Re: girdle
No, we have real blocks so we can put 4 bolt main caps on them.
Bret
Old Jul 8, 2006 | 11:47 AM
Re: girdle
the Lt1 im building has been converted to 4bolt.
ive just read around as much as i could on these threads and havent
noticed any mentions of main girdles on lt1s?
are they just not used period.
or is it just overkill but cant hurt, but still why bother?
Old Jul 8, 2006 | 12:02 PM
Kevin Blown 95 TA's Avatar
Re: girdle
With a splayed cap 4 bolt bottom end with steel caps why would you need a thing like that? Or are you asking about a stock style 4 bolt that you want to reinforce? You might want to ask at a Vette forum since most of us here started out with 2 bolt blocks. I know a few guys bought 4 bolt blocks for their rebuild, but haven't heard of a girdle being used. I have heard of other makes using them more often.
Old Jul 8, 2006 | 12:11 PM
Guido67SS's Avatar
Re: girdle
What rpm range are you looking at? The last thing I would skimp on is the oil pan. Use an aftermarket. Get more oil capacity.
If you are runnung enough rpm to require a girdle why in the world would you not increase your oil capacity.
Are you using any type of restrictors in the top end?
Old Jul 8, 2006 | 05:10 PM
Re: girdle
no restrictors.
the Lt1 is a converted 4bolt, billet steel caps.
but they are not splayed.
will the 4bolt still be sufficient, i.
about the girdle, i already have it but is it worth
the grind and mount, grind and mount process.
Old Jul 8, 2006 | 05:23 PM
joe-96z1le's Avatar
Re: girdle
Splayed caps aren't necessary. Straight 4 bolt mains are more than enough for most people. And, return the stud girdle.
Old Jul 8, 2006 | 06:33 PM
Re: girdle
Is it also worth the custom pan to get it to clear?
96SilverRam
Nov 20, 2016 11:19 AM
FryedClutch
Sep 1, 2015 08:24 AM
R@mpage
Apr 20, 2015 10:02 AM
stonedchihuahua
3rd Gen / L98 Engine Tech
Jan 1, 2003 08:41 AM
