gen I and gen II conversions?
Old Nov 3, 2007 | 10:05 PM
evilawd4g63's Avatar
does anybody know what people are talking about converting older or newer heads to the opposite engine.? like I gues gen I heads on an LT1 block?
Old Nov 4, 2007 | 06:56 AM
1racerdude's Avatar
The water passages and oil return on the end of the heads are modified for reverse flow cooling in the LT1,$300.00 to $500.00 depending on who does it.
This is an important area so go for the best quality work.
Old Nov 4, 2007 | 10:05 AM
so is it gen 1 heads on an lt1 block?
Old Nov 4, 2007 | 10:07 AM
It works either way... the Gen II (LT1) head/block coolant passages are not the same as the Gen I head/block coolant passages. You have to alter LT1 heads to put them on a Gen I block, or alter Gen I heads to put them on an LT1 block.
Old Nov 4, 2007 | 05:06 PM
does anyb ody know where to find pics of the mods? I have a 400sbc that I would love to put some lt1 heads on
Old Nov 4, 2007 | 05:09 PM
96ZCamaro's Avatar
Why not use gen 1 heads?
Old Nov 4, 2007 | 06:46 PM
Mortify's Avatar
Maybe he wants a LT1 big block... even though he wouldn't have the benefit of reverse cooling therefore not able to hold the higher compressions that true LT1s do..
I do have my own question though..
Is it possible to convert a Gen I SBC block into a LT1 block?
Old Nov 5, 2007 | 09:52 AM
Putting LT1 heads on a Gen 1 block does not = "a LT1 big block" by any stretch of the imagination.
You can't convert a Gen I SBC into an LT1 block. The entire front of the block, including the provision for the water pump and the Opti are totally different than the earlier design.
Old Nov 6, 2007 | 04:44 PM
not sure where lt1 big block came from??? injuneer is right. I just think that lt1 heads are great. they're cheap, flow great and aluminum. if I could find some aluminum l98 heads I would use those but people are wanting aftermarket head prices for them.
RUENUF
Mar 13, 2016 03:37 PM
Fatdog2
Sep 16, 2015 11:04 PM
NewsBot
Sep 15, 2015 11:53 AM
cmsmith
Sep 14, 2015 09:25 PM
tdigger9899
Sep 7, 2015 10:56 AM
