Gears can i tune
Old Jan 14, 2009 | 11:25 PM
93FIRETURD's Avatar
Gears can i tune
Does anyone know if the speedometer goes through the computer before the guage in a 93? In other words can i have the computer programed for a set of 3.73 gears? I do know that the speedometer gear is not cable drive and when hooked up to a scan tool the tool reads xmph, thanks for any help guys.
Old Jan 15, 2009 | 01:36 AM
bombebomb's Avatar
Not sure on a 93, I know on my 94 the speedo was 25mph off at 55. We just retuned the PCM and got it all corrected. For a 93, you may need to burn a new chip.
Old Jan 15, 2009 | 01:43 AM
93FIRETURD's Avatar
I guess that is what i meant, i am getting a custom tuned prom and was wondering if they can tune the gears into the computer or does the signal go directly to the guage?
Old Jan 15, 2009 | 11:08 AM
Stl94LT1's Avatar
I'm pretty sure on the 93's you have to change the speedo gears to make corrections.
Old Jan 15, 2009 | 12:43 PM
6SpdLT1Z's Avatar
You should be able to tune it via the PCM or via the speedo gear which I believe is in the transmission?
Old Jan 15, 2009 | 03:36 PM
93FIRETURD's Avatar
Dammit all i dont want to have to change the gear its easy to do but hard to find the gears i have been told
Old Jan 16, 2009 | 02:11 PM
93FIRETURD's Avatar
ttt
Old Jan 16, 2009 | 02:13 PM
Did you try a "search"? I know the issue with the 93 speedo corrections has been addressed many times before.
DirtyDaveW
Mar 15, 2015 07:01 PM
97SSdude
Dec 31, 2014 07:43 PM
Nostang 96z
Aug 31, 2002 12:01 PM
