Gear change on a 93
If I was to change the gears in my car I just have to adjust the speedo right?
I don't have to re-program the PCM right? I have a 700R4. |
You have to get a speedo recalibration box and splice it into the wiring harness. It's like $80 from SLP, but I caught wind of a rumor that they quit selling it. The speedo can't be reprogrammed by doing a computer chip.
Can't you get a gear clip for the speedo cable from GM that would make it 3.73s?
Just change your speedo geers....it'll save you a lot of money compared to the SLP recalibrator
Just pull the tail housing off and the driven gear/sensor the plastic gear on the mainshaft is stubborn comming off. swap both gears and this will be hunky dory.
Originally posted by carnutz Just pull the tail housing off and the driven gear/sensor the plastic gear on the mainshaft is stubborn comming off. swap both gears and this will be hunky dory. thats what i did and it worked great got mine for less than 30 bucks from slp when i got my torsen oh and it is a PIA to get the main shaft gear off have fun cause its way cheeper:thumb: |
Awesome thanx guys!
