gas pump
Old Oct 13, 2014 | 10:45 PM
izzys97z28's Avatar
gas pump
What's a good gas pump for a 97 z28? Also will the gas pumps from 98-02 camaro will fit on the 97 or is it different?
Old Oct 14, 2014 | 11:13 AM
Re: gas pump
Are you looking for a stock capacity replacement, or do you need something with a larger capacity than stock?
Old Oct 14, 2014 | 08:47 PM
izzys97z28's Avatar
Re: gas pump
Stock replacement nothing fancy car is all stock 0 modes since I have to do emissions still I don't really want to change anything its running lean and low fuil pressure I have a friend whit 2 fuil pumps one is 98 the other is 02 camaros if they are the same I would rather use one of those since they are new if not I need to buy one that's my dilemma
Old Oct 15, 2014 | 07:39 AM
Re: gas pump
A lot of people opt for the Racetronix 255 LPH high pressure pump. But you don't need that capacity if you aren't planning any significant HP upgrades:
https://www.texas-speed.com/p-2601-r...t1-f-body.aspx
Racetronix shows different part number for the 93-97 LT1 pump, the 98 LS1 pump and the 99-02 LS1 pump.
Old Oct 15, 2014 | 09:04 AM
izzys97z28's Avatar
Re: gas pump
I saw someone around here asking if 95 and 97 are the same gas pumps and some one said no I was just thinking maybe 97 and 98 ls1 might be the same pump I'll do more research on it thanks
Old Oct 15, 2014 | 10:40 AM
Re: gas pump
I can't think of any reason the 97 pump would not be like the 93-96 pump. Nothing changed over that period.
ad356
Apr 16, 2015 05:38 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
Deadbolt24
Jan 19, 2015 01:29 PM
simple
Aug 11, 2002 11:56 AM
