Fuse #3 15A PCM BATT fuse blowing
Old Aug 15, 2010 | 02:27 PM
SSSean's Avatar
1997 SS died on way to work.. Dont hear fuel pump prime when turning key, found #3 PCM BATT Fuse blown.. Replaced it and blew as soon as ignition was turned to on position.. Any thoughts?
Old Aug 15, 2010 | 03:15 PM
You have to look at everything that is on the circuit and find out what's drawing excess current, shorted out, etc.. There's a list in your Owner's Manual that show what's on each fuse. If you don't have a Manual, Shoebox has a link to them online:
http://shbox.com/pdf/manuals.html
Old Aug 15, 2010 | 04:14 PM
SSSean's Avatar
thanks Fred.. Down loaded the manual. says: Powertrain Control Module
(PCM), Fuel Pump Relay are controlled by fuse. I replaced the Fuel Pump Relay and blows fuse. When the fuel pump relay is removed does blow.. Is this pointing to the fuel pump?
Old Aug 15, 2010 | 04:19 PM
Is that what you meant to type?
Old Aug 15, 2010 | 04:23 PM
SSSean's Avatar
whoops.. I mean to say when I take the fuel pump relay out the fuse does NOT blow.. Thanks.. Sean
Old Aug 15, 2010 | 04:40 PM
Seems like either the relay is shorting or there is something causing the fuel pump circuit to draw excessive amps. Could be anything from the relay to the pump, or the pump itself. Could be a short in the wiring harness from the relay to the pump.
Old Aug 15, 2010 | 08:17 PM
SSSean's Avatar
found the short.. hard to believe it didnt blow up.. Maybe good thing I had a full tank.. Time to research fuel pumps.. Thanks for your input..
Old Aug 16, 2010 | 05:19 AM
Be thankful the fuse blew......
Old Aug 16, 2010 | 07:14 AM
SSSean's Avatar
Yea I see that.. Glad I didnt opt for the bigger fuse to see what would happen.. The wires to the pump got so hot the insulation melted of the wire and melded them together..Name:  DSC08338.jpg
Old Aug 17, 2010 | 02:47 PM
Procharged94Lt1's Avatar
Putting in a bigger fuse to "see what happens" is always inviting bigger problems.
Glad to see you found the problem and it didn't turn into a bigger mess.
Old Aug 17, 2010 | 03:08 PM
Chaos1187's Avatar
Wow...I thanked God for you bro.
Aug 18, 2015 07:08 AM
malikot02SS
Aug 15, 2015 01:11 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RUNMYTA
Jul 15, 2015 07:50 PM
