Fuel System....
Old Jul 17, 2006 | 06:23 PM
jmangler's Avatar
Fuel System....
Whats the best Fuel Set up I can get without going with a Fuel Cell. I was going to go with the Aeromotive Eliminator EFI system but I would need a Fuel cell and I dont want to go that way. Are any of you running a intank set up, so that you don't need a Fuel Cell/Sump pump, and does it still give you the Volume you need.....
Old Jul 17, 2006 | 06:38 PM
1racerdude's Avatar
Re: Fuel System....
Racetronics makes a duel in tank unit but ya have to call them to get it,if that's the way ya want to go.
I've got a Aeromotive 1000 with a sump in the stock tank but ya don't need that unless ya got a blower or BIG HP.
Old Jul 17, 2006 | 09:19 PM
jmangler's Avatar
Re: Fuel System....
Where did you get the sump from. Is it specificly design for the Camaro? Or did you have it custom made? Someone said I can get A/N fittings welded in the bottom of the tank...
I need a good fuel system!
383 Forged low compression, heads extr...
D1SC/ FMIC 14psi
75lb injectors...
Old Jul 17, 2006 | 09:27 PM
1racerdude's Avatar
Re: Fuel System....
D1SC/ FMIC 14psi
75lb injectors...
Look in the Summit catalog. Then ya got to get someone willing to weld and cut on a tank that has had fuel in it. Some radiator shops will do it if ya take it out.
The D1 would warrant a call to Aeromotive.
Old Jul 17, 2006 | 09:35 PM
jmangler's Avatar
Re: Fuel System....
I will have to empty it out and flush it out with water then let it air out for a while. Hopefully I can find someone to weld it up!
CaptainObviousI
29
Apr 29, 2021 10:35 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
2001CamaroGuy
Apr 5, 2006 10:56 PM
tbyrne
Jul 2, 2002 05:37 PM
