Fuel question.....
Old Feb 10, 2004 | 12:42 AM
Heatmaker's Avatar
Advanced Member
Fuel question.....
A pretty good mechanic I know reccomended I upgrade my injectors and add a FPR to my car...said it would be like turining on a light switch in the car...is there a signifigant notice with upgraded Fuel injectors and a FPR?
Opinion please....reccomendations...?
Old Feb 10, 2004 | 12:49 AM
QCKZ28's Avatar
AFPR are pretty much useless.....
1. what kinda mods do you have?
Old Feb 10, 2004 | 01:15 AM
Heatmaker's Avatar
Advanced Member
a buch of crap...but lets pretend I have my super cam...stG2 LT4 heads and 1.6's....
Old Feb 10, 2004 | 01:17 AM
bdc95ta's Avatar
adj. fpr no, injectors most likely not (depending on mods) despite what some say ac delco makes decent injectors that can handle a lot of hp.
Old Feb 10, 2004 | 01:23 AM
bdc95ta's Avatar
check out f-body.com they have a cal. on there that will give you a very close calculation of what lb fuel injector you will need.
Old Feb 10, 2004 | 09:43 AM
Skedaddle's Avatar
What year is your car? (might want to use the signature field for something "useful" ) Not all years respond the same.
That said, with heads and cam, you already have custom tuning, and that tuning should reflect the size injectors you are using and the fuel pressure you are currently operating at. Trying to tune with an AFPR is a real band-aid, and doens't generally work. It will allow you to "increase" the flow rating of your injectors, if they are marginal for your current HP level, but that's about it. And that "increase" would need to be reflected in your PCM constants.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
2001CamaroGuy
Apr 5, 2006 10:56 PM
tbyrne
Jul 2, 2002 05:37 PM
