Fuel pump whine when at partial throttle
Old Jun 27, 2009 | 10:39 AM
Jazsun's Avatar
If Im just cruising at around 60 in 6th gear and I have the pedal pushed in 1/2 an inch or an inch to maintain speed. I get this whine noise from the back, and if I modulate the throttle the sound will follow. However if I push the pedal in further to the point where the engine is underload now it will go away. I dont hear it during city driving, likely because the pedal is pushed in more.
Old Jun 27, 2009 | 11:29 AM
You sure it isn't the differential/gears?
Old Jun 28, 2009 | 04:20 AM
BlackBird97's Avatar
I'm with injuneer on this one. When was the last time you changed your rear diff fluid? How many miles on the car?
Old Jun 28, 2009 | 10:36 AM
RamAir95TA's Avatar
Definitely differential/gears - no question.
Old Jun 29, 2009 | 10:38 AM
Jazsun's Avatar
Im pretty sure its not the rear differential/gears, because if I just move the gas peddle a 1/4 inch I can change the whine noise pitch, and if I push the pedal in an inch it won't make any noise. It's only when im cruising at a constant speed and the pedal is barely being pushed down (just enough to maintan 65 in 6th gear), if I take my foot completely off the pedal the noise will stop instantly, and if I just push the pedal in a tiny bit it will come back, untill I push it in maybe an inch and the engine comes under load again then it will dissapear.
I changed my rear diff fluid about 25k ago, the tailhousing does seap (like all fbodys) and I just recently pulled the filler plug to check the level and oil still came out, but I still squirted some fresh stuff in and closed her up.
Old Jun 29, 2009 | 02:27 PM
RamAir95TA's Avatar
Still sounds drivetrain-related to me. The pump runs at constant voltage/pressure. It won't change with throttle position. Had the same thing happen to me.
GEARS/DIFFERENTIAL!
Old Jun 29, 2009 | 04:40 PM
Jazsun's Avatar
GEARS/DIFFERENTIAL!
hmm yeah that does make sense, for some reason I thought that fuel pressure/pump pressure changed at throttle position. Is gear whine like that a good sign that my rear is about to take a crap? Or do you think an oil change + the GM additive will fix it? The last time I did the rear oil I put the additive in.
Old Jun 29, 2009 | 07:39 PM
andysc's Avatar
The gear whine is not a good thing. Your first thing to do is to change the fluid and put some gm limited slip additive in. Do NOT use any other brand than the GM stuff. You may also want to consider using synthetic gear lube. Double the price but it the whine is bearing related, could make a difference.
HTH
Andy Schuck
kaoticcamaross
Feb 17, 2015 03:13 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
