fuel pump on the way out?
Re: fuel pump on the way out?
This could be your problem. If u have access to a fuel pressure guage u can find out for sure. Your pump might not be holding pressure when its being primed causing it to have to really work the fuel up there. If u get a pressure guage hook it up and turn the key, if the pressure shoots up and then falls off pretty quick then its time for a new pump. Peace, Dustin.
I thought this issue could also be caused by a malfunctioning regulator, or leaky injectors? I have gotten many responses from my own post about hard starting.. and the advice all starts with getting a fuel pressure guage.
