Fuel pump trap door walkthrough link?
Old Oct 14, 2004 | 02:56 PM
Pasky's Avatar
Anyone have the link to the tutorial? I need the part # for the trap door also. Also does anyone know where I can pick up sheep metal shears and how much they cost? I got a A/F of 16:1 . My v6 fuel pump is dying and I can't drop the gas tank my exhaust is all welded. Thanks.
Old Oct 14, 2004 | 03:07 PM
GREGG 97Z's Avatar
Re: Fuel pump trap door walkthrough link?
I did the trap door, there is no part # for the door, at least not for the 4th gen. I cut it out with sheet (not sheep) metal sheers and made a panel to cover it. I already had the sheers but you can get them at Home Depot or any other hardware store for $5 or so along with a piece of sheet metal to cover it. I used a piece of 22 ga sheet metal for the door. There are guides for it here, just search for 'fuel pump' or 'fuel pump door' and you'll find it.
Old Oct 14, 2004 | 03:12 PM
Pasky's Avatar
Thanks man, yea brain fart on the "Sheep".
Old Oct 14, 2004 | 03:44 PM
Spinner's Avatar
Use SMALL sheet metal screw, dont forget the tank is right up against the metal, would suck to screw into the tank on accident.
Old Oct 14, 2004 | 03:48 PM
Myxtreme1's Avatar
Try this... http://www.worldisround.com/articles/12533/index.html
Let me know if that helps!
cmyname1
Feb 19, 2015 08:38 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
