fuel pump relay - where is it
Old Mar 21, 2003 | 09:00 AM
dajohns2's Avatar
ive looked on the driver's side fuse panel: nothing labeled fuel pump relay.
ive looked in the fuse box in the engine bay: again no fuel pump relay.
took off the plastic cover right beneath my stirring wheel to unveil all the eletrical connections, still couldnt find it.
can somebody inform me where it's located.
thanks,
dale
Old Mar 21, 2003 | 09:03 AM
Bastardcat's Avatar
This link is for a 95--not sure if it's in the same spot on the 96.
http://csce.uark.edu/~jgbertr/rb/fuel_pump_relay.jpg
Hope this helps.
Old Mar 21, 2003 | 09:15 AM
dajohns2's Avatar
Thanks,
Also, if the relay is had failed, would you still be able to hear the pump wind down after turning the ignition off?
my thought would be no, you wouldnt here the pump.
Old Mar 21, 2003 | 09:24 AM
Originally posted by dajohns2
Thanks,
The relay should be in the same place.
Heh, I have never heard one wind down. Are you sure it is the fuel pump you are hearing and maybe not the fans?
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
