Fuel Pump questions...
Old Jul 28, 2004 | 01:29 AM
Heatmaker's Avatar
Advanced Member
What kind of fun can you have with a high flow 255lb fuel pump?
Noticable difference?
Same crap?
Old Jul 28, 2004 | 08:41 AM
Heatmaker's Avatar
Advanced Member
Re: Fuel Pump questions...
Yawn.....
Old Jul 28, 2004 | 08:51 AM
MetallicTrans96's Avatar
Nos :d
Old Jul 28, 2004 | 10:42 AM
Heatmaker's Avatar
Advanced Member
what about Nos?
Old Jul 28, 2004 | 10:50 AM
Red96Lt1's Avatar
It won't gain you any horse power, but they say that they are good for up to 800 HP.
Old Jul 28, 2004 | 10:53 AM
Heatmaker's Avatar
Advanced Member
I'm currently having Fuel problems... In reference to getting the fuel where it needs to be more efficiently.... is the 255lb good?
Planning on:
Z06 MAF (got the old MAF wet)
255lb Walbro
Hyperjunk Fuel Pressure Regulator (screw the PCM I'll try it anyway)
36lb Injectors (I think mine have had it)
Should that be some good performance gains fuel wise?
Old Jul 28, 2004 | 11:00 AM
Red96Lt1's Avatar
Yeah, that's what I got. It would take alot to use it to the max. So that means that it's duty cycle will be very low, which is good. Maybe as low as 5-10% during normal driving.
Old Jul 28, 2004 | 11:14 AM
simple's Avatar
you running some big AFR's or dry nitrous, why the 36pph injectors?
Old Jul 28, 2004 | 11:17 AM
Heatmaker's Avatar
Advanced Member
I plan to put the N20 setup back on the car (regret taking it off ) and get the LT-4 stage 2 heads on there. That's the short term goal... the long term goal is a Turbo charger.
I just want to get everything right the first time while I'm toggling with the fuel now.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
