Fuel pump question
Old Mar 7, 2005 | 07:11 PM
  #16
SILVERZZ28's Avatar
Re: Fuel pump question
Originally Posted by Racetronix
Better? 'Is it required?' is the real quesion. A DP is more money and requires that your module be sent in to have it adapted / welded / wired etc...
More money? How do you figure? A bap is 250+ and 1 pump is $120.
You can do this setup $120+$120+Y-block $25.00.
http://home.mchsi.com/~camarozz/dual.jpg
What module are you speaking of? Once you get into mods this high,nothing is just bolt on anymore....
Old Mar 7, 2005 | 08:39 PM
  #17
Racetronix's Avatar
Thats does not look like any Racetronix DP setup! Let's compare apples to apples here! Our DP system is a complete PnP drop-in. No mods required period!
Old Mar 7, 2005 | 09:13 PM
  #18
SILVERZZ28's Avatar
I never asked about your setup man. I was saying in general
Old Mar 7, 2005 | 09:41 PM
  #19
Racetronix's Avatar
Originally Posted by cliff929
I have a 383 and my fuel pump just went out. What is the highest flowing intank pump out there right now. Is it the walbro 340? Does that mean that pump flows 340LPH? I Do plan on spraying the car with at least a 150 shot until I can afford a fuel system rebuild. Will it be safe to spray with a intank pump and a 150 shot? I have about 420rwhp through a TH400 and a 3800 stall. Not sure if I will be pushing the limit. I would replace the whole system now but funs limit that right now. Any help would be appreciated. Thanks
Back to the subject at hand...
A single in-tank Racetronix system will support apx. 550 RWHP depending on your motor's BSFC and the max. fuel system pressure. The Walbro GSS340M flows 255L/Hr @ 43.5PSI @ 13.5V. There is no such thing as a Walbro 340L/Hr in-tank pump. Since your motor is most likely N/A you might be able to support over 600RWHP safely if you maintain the system pressure at apx. 43.5PSI. We always recommend monitoring your fuel pressure under WOT to make sure there is no pressure drop occurring. While some people may quote higher numbers that they or others may have achieved using the Racetronix system we can not endorse their findings / recommendations. We must always side with caution and maintain a healthy safety buffer to avoid motor damage should the pump be subject to adverse conditions.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
