Fuel pump install problem...help please.
Old Jun 17, 2004 | 01:11 PM
hambone3441's Avatar
Ok I went in from the top and got everything set up but have a leak....... the connection that is more to left(hardest one to get to) is the one leaking. I have a black plastic piece that came out and I did not put it back in(wasnt sure where it came from). There is a yellow o-ring too right? Well what order do these parts go in and is the lack of that one plastic piece my problem. Thanks for any input.
Rob
Old Jun 17, 2004 | 08:19 PM
ttt
Old Jun 17, 2004 | 09:27 PM
ninetythreez's Avatar
Question
r u talking about the black piece on the fuel line that the yellow clip fits into? The yellow piece goes on one side of the fuel line and fits into the black piece on the other side of the line to connect together.
Old Jun 17, 2004 | 11:43 PM
camarokid24's Avatar
Are you talking about the fuel line disconnects? Mine was a black female end and blue clip on the male end of the fuel sending unit. Maybe they have diferent colors Well if those two ends are not connected togeather completly then yeah you will have a leak , a big one. Those lines a a PITA to get to with the trap door method.
Old Jun 21, 2004 | 07:37 PM
Well ran into one snag.... pinched o-ring. got to go and order/get one from chevy tomorrow.. other than that the install was pretty easy, will be up and running very soon.
Old Jun 21, 2004 | 09:10 PM
there are some guys on the message board here that work at Chevy parts dept's and can get the parts overnight and probably save you some $$$! Somebody help this guy out!
Old Jun 23, 2004 | 09:56 PM
It lives......... got the o-ring replaced, runs great have to do a little cosmetic stuff still but all is well now.
Rob
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
