Fuel Pump Install Problem
Old Mar 22, 2004 | 08:22 PM
RealQuick's Avatar
I cut my access hole, but nmow I cant pull the pump assembly out. Any tips? Once I take the nuts off that hold the assembly to top of tank, can I just pull it out, or do I have to reach in and disconnect something? I did a search, but havent come up with anythings thats help me so far. Any advice would be appreciated.
Old Mar 22, 2004 | 10:10 PM
Red96Lt1's Avatar
I had the same problem on friday. You probably need to cut your hole more toward the front of the car (leave about .5 inch for strength) and reach in the hole towards the driver's side front of the hole and disconnect 2 of the lines with needle nose pliers. The other 2 just pull apart. Hope that helps.
Old Mar 22, 2004 | 11:57 PM
OBE1 95Z28's Avatar
Here's a pretty good link to verify you have everything disconnected.
http://www.stevenetworks.com/f-body/fuelpump.php
Old Mar 23, 2004 | 09:21 AM
RealQuick's Avatar
Thanks guys. I'll give it a try.
Old Mar 23, 2004 | 11:50 AM
93transam1234's Avatar
If i am correct after you take off the bolts you have to turn the meatel ring that holds the pump in,
I think i used a flet head screwdriver and turned it then it should wiggle around and you can pick it up a lil
Old Mar 23, 2004 | 12:13 PM
RealQuick's Avatar
Yeah, I can lift it about 4 inches until the piece on the inside that is bent @ 90 degrees hits the top of the tank. I am about to try red96's idea.
Old Mar 23, 2004 | 01:17 PM
RealQuick's Avatar
Those steps worked perfect. Thanks dude.
Old Mar 23, 2004 | 01:19 PM
Red96Lt1's Avatar
No prob man. I was cussing when I got to that pont too!
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
