fuel pump fuse/relay
Old Dec 17, 2007 | 03:40 PM
vipercrt's Avatar
need to depressurize the fuel rail and injectors. Where is the relay/fuse so I can do this. Otherwise, what is the best way to do this?
Old Dec 17, 2007 | 04:04 PM
All you need to do is depress the shrader valve on the fuel rail.
Old Dec 18, 2007 | 01:35 AM
'94 Bad A Z28's Avatar
You can do it the way shoebox said, it's a little messy but it works. The relay is located underneath the driver side kick panel. The "foot rest" next to your brake or clutch, depending whether you are A4 or M6.
Old Dec 18, 2007 | 07:15 AM
Of course, you would use a rag to catch any fuel. That's a no-brainer.
Old Dec 18, 2007 | 08:05 AM
AXEMAN's Avatar
It is a simple fix, I changed mine and didn't need to but it was so easy I didn't mind.
Old Dec 18, 2007 | 11:25 PM
Somebody might not think of that since you said it and didn't mention that.
Old Dec 18, 2007 | 11:47 PM
TobyZ28's Avatar
The mess free version is to depress the schrader by hooking up a fuel guage to it, then just use a catch can on the tube
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
